Your starter button is a two position switch. The lights are supposed to go dim when the button is pushed halfway in. When pushed in all the way it should activate the starter solenoid. The starter solenoid is located under the seat next to the battery. You can follow the positive battery cable directly to the starter solenoid. If you push the starter button and the starter solenoid clicks, then the starter button is good. If the you unplug the two smaller wires going to the starter solenoid and connect a voltage meter to the main harness leads , the needle should jump whenever you press the starter button. If it does not clean the button contacts or replace the right switch assembly. If the starter button is good then take a jumper wire and short across the two battery cables on the starter solenoid. This will put power directly to the the starter. If the starter works now replace the starter solenoid. If your starter still does not work, try holding the starter button and tapping on the starter with a plastic hammer. If the starter works now then you probably need to replace the starter brushes. If anything else is wrong with the starter you will need to replace the assembly as the dealer will usually only offer the starter brushes for repair purpose.
David's answer is absolutely correct! But I feel compelled to mention the kickstand sensor. If it's out of alignment and the bike is in gear the starter won't engage. If the bike is in gear and the kickstand is down, the starter won't engage.
