All y'all are wrong. It can be fixed. This is one of the only lcd with an actual GLASS front on top of the panel. I cracked mine and got it replaced for about $300
that model doesnt have any replacable bulbs. there are no consumable bulbs or lamps for that model. what is the problem with the tv does it not turn on? that model was notorius for power supply failures where the tv would try to power on and get a green light on front and come on and off 3 times.
This sounds like the panel itself is cracked. If this is the case, the set wil not completely power up as youi have seen. The panel can not be repaired as such, it must be replaced. I can rpovide you with the part number and cost if you can post the model number. Be aware however, that the cost of the panel may come close to the cost of a replacement set.
Some, but not many have the front glass as a replacement, give me the model number so I can check. Oh, pioneer is getting out of the tv business this year ( soon ) if it turns out that the glass cannot be replaced or even ordered you might not feel to bad. They are one of the best at car audio, they decided to go back to the core of there business---------great idea!!!
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
whats the model number of your set? please respond to this same post and i will help you with the problem. if you remove that panel before getting a replace ment you wont be able to see your TV correctly.
If the glass that you can feel on the front of the tv is cracked, then just replace the glass (called filter). The cost is about 150.00. If the pannel is cracked buy a new tv. It costs to much.
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
