SOURCE: Lexmark 4300 not loading paper correctly
Look down the paper feed into the printer you will see one white plastic roller. Find a cotton bud and soak the end in methylated spirits and poke it down and wipe the roller. make sure you wipe the whole circumference of the roller. This removes any grease that has come off the paper onto the roller and allows the roller to grip the paper better. I have done this once and have not had a recurrence of the problem.
SOURCE: setting top of form for zebra 2844
Hold down the green button, then power on. As soon as the light turns red, release the button. The printer will go into calibration mode. When complete, press the green button one more time.
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to loading the paper . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Please try below steps if you want to know how to load paper in to the Feeder.:
Important: When loading paper into the feeder, make sure you are using separated (i.e., cut) sheets of paper. Banner paper that is connected end-to-end should not be used unless you are specifically printing a banner.
To load separated sheets of paper:
Humid conditions may cause some sheets of paper to stick together.
If the issue still persists, then I recommend you to look in to USER MANUAL that is provided along with Printer for instructions on loading Paper.
Well, for your convienience I'll provide you with steps that helps to access USER MANUAL.................
Steps are :
This should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at [email protected] . I'll be glad to help you.
Bye.
