SOURCE: Craftsman 16 hp 42 in. riding mower won't run when clutch is released
If the engine feels like it is being choked, then something might be catching or bound up...for example the blades may have been installed improperly and will not rotate. Make sure that you can rotate the blades by hand...if not they may have been tightened and are binding against the mower housing.
If there is no engine choking...then it may be electrical for example a bad fault switch...take it to your mower shop.
good luck
SOURCE: My Craftsman G5000 mower chokes off when I release the clutch
bad ropes safety switch under the seat.
SOURCE: Craftsman 15.5 HP, 42" deck
Check that the seat switch is functioning, pull the seat up and put a paperclip in the switch and try it that way if it works then you need to replace the safety seat switch.
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Testimonial: "Haven't tried the suggested solution but makes sense."
