Bosch Exxcel WFO 2264 Front Load Washer Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Someone cross threaded the drain plug in our WFO 2460 washer and now we can't loosen it. I'm trying to troubleshoot problem where the washer won't go throuugh any cycle won't spin or drain just counts down through the cycle time in about 2 mins. Any ideas to loosen it.
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Jun 16, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025588
Points
20216
Are you sure it is cross-treaded or just plain gummed up? If it is cross-threaded there is only one way to remove it- with force! Otherwise- suggestions ;- pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Testimonial: "Thanks I did try it but it still wouldn't come off. I took it to the repair man. A sock got caught in the filter system. "
How to put drane plug back min
push and turn it in a loosen direction until you feel or hear a click. then turn it in a tighten direction.. that should line up the threads .. if you cross-threaded it you might need to buy a new plug .. they are pretty cheap ..
1helpful
Water running out of small orifice in back of unit
If that small orifice you're speaking of is just above floor level. That's the drain plug for draining the tank. It may simply be loose and needs to be tightened or it was cross threaded when it was last drained and reinstalled.
In either case, turn the unit OFF and unplug it. Remove the drain plug and drain the unit as you normally do. Then reinsert the plug, and tighten it, being careful not to cross thread it or over tightening and cracking it. Although your model has an evaporation feature, there are times the bucket needs to be emptied.
I hope this helped you and thanks for choosing FixYa.
26 gallon model 919.167700 160 psi 1.6 hp Bottom of the compressor has a threaded air relief valve that cannot stop the compressed air from escaping. The compressor is new?! I tried using teflon tape...
if it's leaking from the center ,try loosening it let air blow out & tigthen .--- if it's leaking from the theads try tigthening it some more without breakage //////// this valve is the same as a metal radiator petcock with pipe threads that are tappered // return the compressor if still under warranty or try pipe dope -- check for crossed threads--buy new petcock from auto parts store .....a street elbow & 4'' of pipe & quarter turn vavle from the home depot ( or similer supply store ) works nicley as a replacement / this way you can reach the valve to drain the water with out laying on the ground.--------------1/4 pipe thread i think .
2helpful
Got a Bosch WFO 2460, drum stopped turning, replaced brushes and cleaned up the stator but it still wont work. When it stopped the first time it triped the Mains circuit breaker so i am wondering if there...
there is a thermal cut out located in the windings on the motor you may have o hunt for this it has a wire going in and n out, you could short it out as a quick test if motor running....
Replacing a Transmission drainplug on a 1999 jeep cherokee
The plug should have a nylon washer on it that prevents leakage. If you are all finished and it's not leaking than you have done well. If you have a leak there, first check to see if the washer is there and not cracked, If it is get another washer. Sometimes using a wrap of teflon tape on the threads will help if washer is good but still leaks. Don't wrap entire thread though...only the half closest to the head. If any tape gets into the unit it can play hell with the valve body.
I cannot unscrew the cap next to the draining hose situated bottom right hand corner in the base behind clip on cover.
It IS difficult. Try something to give you greater leverage. I use channel locks, and grab the middle part of he cover. There's an "O" ring behind the cap. When you do get i off, spray the threads and "O" ring with some silicone spray.
Best Regards, --W/D-- Please feel free to rate this solution!
Drain screw
He, if the repair was done within their warranty period, try calling their service department. It should be covered...beyond that, I would say that someone either overtightened or cross threaded the drain screw. You might warm up (but not fully presurize) and see if you can loosen it 1/4 turn counter clockwise (no further) and let it cool before removing.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
