Refrigerator stopped working Followed troubleshooting in manual Cleaned coils (they were dusty) Checked electrical outlet (working condition) Made sure light goes off in unit when door is closed Made sure unit on switch is actually on Temperature Controller is lit and set at 40 degrees-no lights flashing
Hi! It sounds as if, after you followed everything recommend in the Owners Manual and it still doesn't work, than either one of the relay circuits to the compressor or the compressor itself, has failed. As far as troubleshooting this problem is concerned, it's a process of elimination. Check the circuits first with a multimeter. If you have power on the incoming side of the relay circuit, but none on the outgoing side to the compressor - it's a circuit problem. If you have power on both sides, then but the compressor fails to turn ON, it's the compressor.
U-Line has discontinued this model, but parts are still available thru one of their service centers around the country.
Below is a link to there Customer Service Contact page. There you can locate a service center near you.
http://www.u-line.com/customer/contact.cfm
Hope this helped you. Please let me know. Thanks.
Hi, are you talking about light indicator for
Refrigerator?
You can unplug the machine. Then take out the bulb. Inside the socket at the
bottom is a metal tab that makes contact with the center of the bulb
base. It is common for this little tab to get pushed flat and not
actually touch the bulb. Using a small screw driver, bend this tab up
about 1/4 inch. Put the bulb back in, and pug the unit in.
Let me know how you did.
You can also use the below link to watch a video on how to check the light.
http://www.ehow.com/video_8168853_repair-refrigerator-light.html
Hope it helped
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
No, I know how to put a new light bulb in.
The light is supposed to go off when the door closes, which it does. Bulb is fine.
The refrigerator is not working. Not operating/running.
Uline undercounter Refrigerator not turning on.Cleaned coils (they were dusty). Temperature control light is on (so electricity is working). Refrigerator not running. Last expert told me to change the lightbulb! I will give this another try...
Yes, answered my question! Thank YOU
