SOURCE: My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
SOURCE: Refrigerator stopped working Followed
Hi! It sounds as if, after you followed everything recommend in the Owners Manual and it still doesn't work, than either one of the relay circuits to the compressor or the compressor itself, has failed. As far as troubleshooting this problem is concerned, it's a process of elimination. Check the circuits first with a multimeter. If you have power on the incoming side of the relay circuit, but none on the outgoing side to the compressor - it's a circuit problem. If you have power on both sides, then but the compressor fails to turn ON, it's the compressor.
U-Line has discontinued this model, but parts are still available thru one of their service centers around the country.
Below is a link to there Customer Service Contact page. There you can locate a service center near you.
http://www.u-line.com/customer/contact.cfm
Hope this helped you. Please let me know. Thanks.
SOURCE: My Uline Echelon refrigerator drawer
Regards,
Tony
