The error code is displayed when its beeping. I don't know the error code, so It can only be three things, Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below. Add up the lights that are on.
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Hi Benjimin,just read your posting.Now when the machine stops and beeps it will light up a series of lights.These lights will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 2nd and 4th or the 3rd and 7th ----etc----?Please reply with additional information and I am sure I can help you.
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
the rods have nothing to do with the water level switch. I say check ur water switch with a meter. you may have defective coils, also check the water pressure switch
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4. I un-seized it with some electrical cleaning spray, fixed itshort term, no worries. Thanks Stephanos 18.
