LG W2286L Monitor Logo
Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black screen with.com lg logo and "energy save
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Jun 10, 2011
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1158315
Points
10260
This only happens when computer is on standby or there is no activity by a human like movement of mouse. it is a built-in energy saving formula on all such monitors
1helpful
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
My E520 Dell shuts down in to the energy save mode after 1 minute of booting and then the high speed fan comes on and screen goes black
off the energy save mode...it goes revert of ur action...re-install opreating system..is it work? clearfy
I am getting a black screen with lg logo and "energy save mode". how can i come out of ths problem?i
did you try your monitor connecting with some other PC? it may be you PC problem not monitor .
Power Saving Mode. Black screen how do I turn it off?
If you can bring up the menu on your T.V. go to your power settings or energy star settings. Under your power settings or energy star settings you should be able to turn power saving mode off. If you can't power up the T.V. then there is probably a problem with the circuit board that would require a repair. If it's still under manufacturer warranty or protected under an extended warranty that you bought, then you should be taken care of.
2answers
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
TOM TOM GOES BLACK WHILE DRIVING
It appears that you do indeed have the system on energy save, go back into set up and un check power save mode.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
