That isn't a complete model number. I found three models at Sears Parts Direct that started with110.2234* . Click on the Models tab at https://www.searspartsdirect.com/search?q=110.2234 . The three machines use the same parts. The parts diagram for the Kenmore 110.22342511 top load washer here:
https://www.searspartsdirect.com/model/3219xhjolw-000582/kenmore-11022342511-washer-parts . The upper agitator is given a different number on the basket diagram for some of the models. However, the current replacement is part W10836692. This is back-ordered at Sears Parts Direct. It's listed as in stock at https://www.maytagreplacementparts.com/PartDetail/Upper-Agitator/W10836692/4363274 and https://www.appliancepartspros.com/whirlpool-agitator-w10836692-ap5988691.html .
Kenmore manuals almost never list the full model number. They make one for several models in a line or multiple lines. In this case, the manual covers two series: 110.2234xxxx and 110.2244xxxx washers. 110 means that the machines were made by Whirlpool with the Kenmore nameplate. Manuals Lib has a copy of this manual here:
https://www.manualslib.com/manual/1327493/Kenmore-110-2234-Series.html . In the future, you can usually find the model number in one of several places on the washer. Check for the label on the back of the control panel, on the back in the upper left corner. or inside the washer on the frame under the lid for a top-load machine. There are a few other spots where the label could be but those are the most common. I hope this helps.
