Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
