liftmaster Garage Door 1/2 Hp Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I Re-Programed the control remote but it still doesn't close the garage door.
robert
Level 3:
  • Master 2,548 Answers
  • Posted on Jul 10, 2015
robert
Master
Level 3:
Answers
2548
Questions
0
Helped
869577
Points
8043
If it does not go down with a single push of the wall button but it will go down if you hold down the wall button, then you have a wiring issue with the safety photo sensors. a broken wire.
Harold Gray
Level 2:
New Friend:
  • Expert 130 Answers
  • Posted on Dec 10, 2014
Harold Gray
Expert
Level 2:
New Friend:
Answers
130
Questions
0
Helped
52714
Points
264
Try closing the door with the wall switch. If closes then you possibly have a bad remote.. If it doesn't close and the light bulb flashes repeatedly then you have a problem with your safety eyes.
Steve Burt
Level 2:
Sergeant:
Champion:
  • Expert 245 Answers
  • Posted on Jun 06, 2011
Steve Burt
Expert
Level 2:
Sergeant:
Champion:
Answers
245
Questions
0
Helped
50093
Points
669
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
2answers
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
2answers
Garage door senser not working
One possible reason. (RF) Interference from an ultrasonic humidifier. The radio wave created to create the mist will cancel out a garage door opener I learned it the hard way I almost replace two garage door opener's but I turned off humidifier and everything worked in my Internet works better now too. Just passing this tip on hope I helped.
1helpful
2answers
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
3answers
Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
1helpful
Garage door will not close when using the remote or garage door button. it will open, however. it can be forced closed by holding the garage door down. i have had this problem before . i have...
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
2answers
Garage Door Remote
find attena and point it to your door if this does not work try adding a piece of wire to attena and making it longer also always check batts...
Top liftmaster Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
