SOURCE: Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
SOURCE: is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
SOURCE: Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
SOURCE: Our whirlpool washer gvw9959kq2 won't drain.
Remove the front panel and the hoses will be accessible. Removing the wash plate is not advised unless you are prepared to replace seals.
Eric
