Samsung FP-T5884 58 in. Plasma Television Logo
Posted on Aug 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blown Picture While watching the olympics, we heard a loud "Pop" and then the display went black. The sound is still on. We turned the TV off and back on but the display is still black. The TV is only 6 months old. Otherwise TV was great. Samsung's Customer Service reviews are horrible. Is there anything I can do to fix on my own?
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Aug 18, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783184
Points
6681
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
1helpful
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Heard pop sound picture went
Your backlight went out. Manual should tell you how to change it
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
2helpful
Pop sound then no picture, just sound
I assume this is a plasma TV? You will have a fuse blown on either the Y or Z sutain board, there is also a possibility one of the driver IC's has blown on the buffer board, this will shut down the screen & leave the audio working normally. You can check these boards which sit on the left & right hand sides of the screen.
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
2helpful
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
2answers
A loud POP. No picture now.
sounds like filter capacitors in the power supply. did you replace the convergence IC's?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
