Your Dispenser may locked or any of it futures there is lock prevents ice or waterfrom being dispensed is well light to operate in sertain way, download here download here complete manual it shows on it how to lock and unlock these futures. Iand I think it is on page 17, to find words quickly on these 112 pages press Ctrl + F and type word you looking for "light" for example. hope that helps!
Check water supply make sure you have ample water and not a kinked connection from supply. It is a common failure on Amana to have a defective Filter/Head assembly.
If the water filter has been changed. And there is water going to the door, then the valve or circuit to icemaker is bad, or the unit or door is frozen.
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
