Frigidaire Affinity ATF7000E Front Load Washer Logo
becky day Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is flashing E90 - Frigidaire Affinity ATF7000E Front Load Washer
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Jun 02, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14458874
Points
60858
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
Good luck.
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
2helpful
Machine flashing E90 and not working.
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
5helpful
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
1helpful
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
1helpful
Big problem with e90
my friend you should flash your phone using one of nokia's flashing software this is your only solution
Washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
