SOURCE: I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
SOURCE: have a Bosch WFMC 3200UC and gives a E04 error.
In order to unlock the door on this machine you must first turn the cycle knob to a cycle that was different than the one you were on. The machine should then reset and the door should unlock.
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
SOURCE: Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by
the machine during the softening cycle, so that the machine does not
completely fill the softening tray; only when the softening tray is
filled beyond the 'max' mark does the siphon action works. A partially
filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the
softening action is that the water inlet of the machine is partial
blocked (you can try to fix that) but it is simpler to just added more
water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every
time (after adding the softener to the softener tray of course) is to
top up the softener tray with extra water, top it up to the 'max level'
line (keep a bottle of water by the machine). That way, even if only a
little water is added to the softener tray during the softening cycle
by the machine it is enough to trigger the siphon action and the tray
will empty!
Works for me every time, and no need to remove any parts - I used to
take the tray out, clean it, scrub the outlet holes that fill the tray
etc, but they used to gum up again quite quickly!
Hope that helps
SOURCE: unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Hello &
Welcome to FixYa
E13 error in
your Bosch WFMC washer is a drain error and is displayed when the drain time
exceeds & the washer is unable to drain so the door won't open sometimes
when this error is displayed. You will have to clean the drain trap in the
bottom right hand corner. You can stick a straighten paper clip in the access
panel located inside the front bottom panel through the whole and then turn the access
panel counter clockwise to unscrew the plastic drain cap behind it. After
everything is cleaned and the error returns then replacing the drain pump is
recommended repair. Please get back to me if you have any other questions.
Kevin
