SOURCE: kenmore 600 series dryer, does
check (if it is gas)power atthe igniter....If there is and it doesnt glow when you start dryer ...Replace the Igniter.....2nd. ..If you
have no power at the igniter ....replace the Thermal fuse (see picture above)
SOURCE: dryer doesnt start
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
SOURCE: kenmore 600 series dryer doesn't
I have a 600 sieries kenmore gas dryer can i use LP or not.
SOURCE: kenmore 600 series gas dryer not warm
My Kenmore 600 gas dryer is running but it does not heat, so I'm not able to dry my cloths.
Take a look at this troubleshooting tip for the no heat problem for your dryer.
