Hello
I had a issue last week with this. the damper was frozen over. turned the temp down on the fridge and it seemed to fix its self. today i wake up the fridge is about 66 degrees, and it wont start cooling again.
i have cleaned the coils and stuff.
i cleaned the holes that go down to the freezer in the back.
i played with the thermostat and can not get it to work.
i took the damper cover off and the thing is wide open, could that be part of the problem or am i looking at more then one problem?
i need to order parts to fix it because i cant afford to get someone out here to do it. I just do not want to order the wrong stuff if possible.
the freezer is working right, and always has been. no frost or warm in it.
please help!!
thank you in advance.
SOURCE: Constant freezing up
Doug, This model has an adaptive defrost board. You can put it into a forced defrost through the control panel. Most of the time I have been finding the control board (Jazz) board to be the culprit. To enter into a forced defrost, open the right door only. Hold the light switch down. Press the refrigerator temp down key 3 times. Release the light switch. Display should show Fd. Press the refer temp down key 1 more time to confirm. Toggle between short S and long L defrost by pressing the refer temp up key. For testing, use the L. Press the refer temp down key once more and you are now in defrost. Now, if you want you can peel the freezer back panel off to see if the heater is coming on. With it in forced defrost you should hear sizzling and popping after a while. To get out of the test mode, just close both doors. The Jazz board, part 12002449, is in line with a defrost bi metal that sits on the evap. If the bi-metal is bulged, that could be the problem. Like I said earlier, I have found in most cases the Jazz board itself to be the problem. Hope this helps you understand the refer a little better...Catriver.
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
SOURCE: Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
SOURCE: Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
