Question about Whirlpool GBS277PDS Electric Single Oven
Cant figure out how to get back to farenheit temp..
I had a power surge several times a couple of nights ago and when my oven came back on the temp had changed from f to c degrees. I cant figure out how to get it back to farenheit. Also, my clock will not stay on now. Any suggestions? The timer does work but the clock wont stay on. After a power outage the temperature has changed from F to C and we cant seem to find a control that changes it. The clock also will not stay lit as it previouly has.
  • shereebickne Aug 16, 2008
    After a power surge last week, our oven only displays temps in celcius and I am at a loss as to how to get it back to farenheit. Our clock does not display the time now either.
    Wow, so simple!! I appreciate your quick and specific response unlike the **** before you who just suggested that I change the settings!! DUH. Thanks again!!
  • 1,031 Answers
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide http://www.ajmadison.com/ajmadison/itemdocs/8300609.pdf
Posted on Aug 16, 2008
  • 1,800 Answers
Give it a soft reset its in the display menu its sometimes referd asto factory defaults or restore inintial settings seek for that in ur menu and apply it and be sure that everything is just gonna be okay rate me as usefull if this not work good
and i will give another solution that give it a hard reset
  • 2,337 Answers
Click here to download the user's guide and go to page # 7 to change from C to F.
  • Jaime Hernandez Aug 16, 2008
    Did you see the link I sent you?
    Sergeant:
    Champion:
  • 230 Answers
Try to change the settings
Anonymous
SOURCE:
We were without electricity for 2 daya following hurricane Irene. When power was restored, the oven display (time, temp, etc) did not come back on. The oven lights come on when the button is depressed. and...
Try turning off the circuit breaker to the oven for 30 min or so and then turn it back on. If it does not come back on the oven probably got a power surge and the control has been damaged. Hope that helps
Aug 30, 2011 | Whirlpool RBD305PD Electric Double Oven
I have a whirlpool accubake oven that is stuck on the celcius temperature and I don't have an owners manual and I need to reset it to farenheit. Please help!
To switch it to Farenheit..press and hold the BROIL button for up to ten seconds and the display of the broil temp will change from 500 to F then push clear/off button...if later on it needs to be switched back to C do the same thing
GENE
Aug 28, 2011 | Whirlpool Ovens
Looking for toastmaster under counter toaster oven
I'm selling a couple on e-Bay. Oldradionut seller.
May 04, 2010 | Toastmaster RA-5T Electric Oven
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
KitchenAid gas range - Err message F5 E7 - cannot unlock door
Normally when storms hit your oven, the electronic control board goes out. That's what has happened to this oven.
Oct 24, 2009 | Ovens
A few days ago, there was a power outage at my home/neighborhood. After the electricity came back ( after 30 minutes ) ...the digital clock ( control panel) on my oven set at LOCK and I cant open my oven...
Sounds like when the power came back on the surge burned out some electrical coponents in the control board. I would suggest taking it to the repair shop.
Apr 29, 2009 | Ovens
Power cut and now cant reset the clock
We flipped off the designated breaker to the oven and turned it on again. We were then able to reset the clock. This has happened to us several times.
Apr 21, 2008 | Fisher and Paykel AeroTech Double OD302...
Power surge, and pad won't work
This may be related to the F7 problem. I have a post on this site.
Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this fix with over 1400 folks and most report success. I hope that it works for you too.
Nov 20, 2007 | GE Profile JKP56 Electric Double Oven
Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
May 19, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool GBS277PDS Electric Single Oven Logo
548 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
