Good day ,please i would like more information concerning your computer issue.1. When you power it on what do you see on the screen. 2. Do you hear any "beep" , if yes , how many times beeps do you hear , please you would need to be specific?. 3 what operational system are you using?. 4. Is power realy getting to your computer?
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette
or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a
memory stick is in a card reader and the computer is attempting to boot from it.
If you have any card reader or flash reader make sure that no memory
stick is inside the computer. Additionally disconnect all USB drives, cameras,
ipods, iphones, etc. from the computer.
If you are attempting to boot
from a floppy diskette and are receiving this error message it is
likely that the diskette does not have all the necessary files
or is corrupt.
If you are attempting to install
Windows XP or Windows 2000 and are receiving this error message as the
computer is booting verify that your computer BIOS
has the proper boot settings. For example, if you are attempting to run
the install from the CD-ROM make sure the CD-ROM is the first boot
device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note:
If you are not receiving the above message and your BIOS boot options
are set properly it's also possible that your CD-ROM drive may not be
booting from the CD-ROM properly. Verify the jumpers are set properly on
the CD-ROM drive.
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the
CMOS setup. Improper settings can cause this
error.
Corrupt NTLDR
or NTDETECT.COM file
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
