Hello Larry...Here are the steps to take. Detach the ground (black) battery cable. Lift the front of your vehicle with a floor jack, support it with jack stands and chock the rear wheels.
Unfasten the retaining nuts holding the heavy (battery) cable and the thin wire to the back of the starter solenoid (the small cylinder mounted on top of the starter motor) with a wrench. Move the heavy and thin wires out of the way.
Loosen the two mounting bolts holding the starter motor to the engine block with a ratchet, large ratchet extension and socket. Hold the motor assembly with one hand and finish removing the two starter mounting bolts. Make a note of the position of each mounting bolt, since they are of different sizes, and of any shims located between the starter motor, mounting bolts and engine block.
Remove the starter motor from the vehicle
To Install:
Position the new starter motor in place with one hand and install the two mounting bolts finger tight with your free hand, along with any shims installed with the original starter. Failing to replace the shims may cause the starter to grind against the flywheel or engage and fail to start the engine
Tighten the two mounting bolts with the ratchet, extension & socket.
Install the heavy cable and wire in their respective mounting studs at the back of the starter solenoid and install the retaining nuts finger tight. Tighten the nuts with the wrench; (careful not to overtighten)
Lower your vehicle off the jack stands...Attach the ground (black) battery cable.
There you have it, included is a picture of the starter, good luck, i hope this helps.
http://www.autopartswarehouse.com/sku/Replacement/Starter/REPB320102.html?tlc=Engine+%26+Drivetrain
