Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad. To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad. To Unlock Press the LOCK Touch Pad for 3-5 seconds until the Red light above the Household water line valve is not open. -open valve Freezer door is not closed-Close door tight Ice & water filter cartridge is clogged-replace filter
Touch Pad goes out.
Other possibilities:
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
