If u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
no, this is for a commercial steamer not an iron. I need to know how much vinegar if this is the solution
use straight white vinegar and heat it like you would with water in it, if you have a salt/calcium build up this might clear it. pins to clear the holes too might get the steam started but use the vinegar
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
this is foe a commercial steamer not an iron
this is for a commercial steamer and i need to know how much vinegar, if this is the solution
