We lost instructions to changing time on the Armitron WR165 watch - the names on the buttons, going from upper left down - across - then up, say:
ADJ ST/STP
MODE LIGHT
Please answer with instructions on how to change the main time!
thanks, Chris Fraga
my email is [email protected]
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
It works!!
I also lost the instruction to my armitron watch and i need help to fix it!!!!!!
I lost my instructions for my wr165 watch
I can not reset the time on my watch either and have lost directions.
I've finally dug mine out of the cave-like hovel called my room. So, I was looking at other places online, and I found several models with the label of "WR165"; So, what's the deal? Just to keep things as clear as they've been so far, mine is digital, has a timer/stopwatch function, says "WATER RESIST" on each side of the strap from the display, and the buttons (going from what would be 12 o'clock, clockwise) are:"ST/STP" - "LIGHT" - "MODE" - "ADJ." And, oh, yeah, I need the time set on mine, too.
When I press A, then B the only functions that blink an I can adjust are the hour and minutes. I can not set the date or day of the week. I need help!!!!!!!
setting hour
