SOURCE: U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
SOURCE: u-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
SOURCE: contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
The manual defrost
reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. Then check, do you notice the same problem, if yes then defrost assembly board is faulty.But in most cases defrost reset procedure helps.-----------
Thanks.Helpmech.
