Clearly, it is faulty and has some type of parasitic drain. All watch batteries should last a couple of years. My Seiko last for about 3 to 4 years. Return it to Pulsar or a repair agent for repair.
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
sadly, if the battery is indeed dead, it's time for a new watch. the cost to replace the battery will be the same as buying another one off ebay, pawnshop, craigslist etc.
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
You'll need to go to a jeweler to get a new battery,usually they have to order it, BE PREPARED for a price shock. ihad to get one for my wife's watch a few years ago $68.00 just for the battery another $10.00 to put it in.
I have the same watch and the same problem. The solar battery is depleted. You need to recharge the watch like you did when it was new. The instructions can be found through the following link: www.pulsarwatches.com.au/manuals_pdf/108_1.pdf
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
