Kyocera FS-3900DN Laser Printer Logo
Anonymous Posted on May 18, 2011
Error call service 4000:00433933 - Kyocera FS-3900DN Laser Printer
karim s
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 17, 2018
karim s
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2143
Points
5
I have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
Hosam Kamal
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on May 31, 2014
Hosam Kamal
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3731
Points
6
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
3answers
Intuit Error 15243
Intuit Error 15243
QuickBooks Error 15243 by Dylan on January 27, 2019 in QuickBooks Help 0
QuickBooks Error 15243 Overview QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update. QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly.
Causes of QuickBooks Error 15243
The various causes due to which QuickBooks error code 15243 occurs are mentioned below:
·Incorrect QuickBooks installation
·Intuit QuickBooks File Copy Service (FCS) is damaged
·QuickBooks FCS service is not enabled
·QuickBooks Payroll subscription has ended
·Damage in Company File
·User not logged in as an Administrator
QuickBooks Error 15243 - Intuit FCS Service is Damaged QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application
·Go to the Start button
·Right-click on Computer/This PC
·Choose Manage option
·Go to Services & Application Tab
·Double Click on Services option
·When you see Intuit QuickBooks FCS, click on it
·Click on the General Tab
·Click on Startup
·Choose the Manual option
·Click on apply
·Choose Start & then Ok
·Now, Reopen your QuickBooks as an administrator
·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription.
Resolve QuickBooks Error 15243 in QuickBooks Payroll ·Open QuickBooks
·Go to the Employees option
·Choose My Payroll Service
·Select Manage Service key
·Click on the Edit option
·Verify your Payroll Service key
·Choose the Next option & remove the check for Open Payroll setup- I want to start right now
·Select the finish option
·After the verification, Go to Employees
·Select Get Payroll Updates
·Download Latest Payroll Update for QuickBooks Desktop & Update
Contact QuickBooks Support to Repair QuickBooks Error 15243 If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243.
Common Errors like QuickBooks Error 15243 ·QuickBooks Error 15271
·QuickBooks Error 15215
·QuickBooks Error 15101
·QuickBooks Error 15214
·QuickBooks Error 15203
·QuickBooks Error 15222
·QuickBooks Error 15262
·QuickBooks Error 15102
·QuickBooks Error 15106
Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message comes on.
About 3,440 results (0.84 seconds) Search Results
    Chassis Settings Service Required - Page 2 - 2004 - 2007 V70R ...
    v70r.com > Home > Volvo > 2004 - 2007 V70R
    Nov 1, 2011 - So, in our case it seems that the shock / strut itself is totally undamaged (at .... As usual, the "chassis setting service required" message didn't show as I ....All of them will indeed need to be replaced when normal weeping ..... Error codes 0115 and 0201 can be related to a low battery, but 0023 and 0113 ...Missing: oem
    www.fixya.com/cars/t26080647-chassis_settings_service_required_error
    1 hour ago - Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message ...
    Volvo S60 R "Chassis settings service required" warning - Swedespeed
    forums.swedespeed.com > Forum > Ask IPD > General Maintenance
    Sep 26, 2008 - 29 posts - ‎15 authors
    Now I have this message "chassis setting service required" Did the guys hit ... My way costly Volvo Service Department wants me to bring the car in for ... The explanation was that there is a defective shock and they ... First try was to replace a strut that gave a error. ... All is back to normal. .... 2004 V70R - GT. "Anti-Skid Service Required"
    Dec 22, 2012
    "chassis settings service required"
    Sep 4, 2012
    Another "Chassis Settings Service Required" thread
    Aug 13, 2012
    AntiSkid Service Required and Chasis Settings ...
    Dec 5, 2
2helpful
3answers
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
28helpful
6answers
Message is Service call error 00010014
SERVICE CALL 00010014
Description
Failure of pressurizing
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
1helpful
2answers
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
2answers
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
