I bought a utilitech three outlet outdoor timer and cannot get it to set. Now I cannot seem to find the instructions that came with it. Where can I download the instructions?
I bought one also but am taking it back today as I am not satisfied with the performance and the internal battery dies losing all programming. The instructions below are word for word from the manual but not all that clear. Since I can't post the diagram from http://www.thencc.com/westinghouse/LS/Instruction/T28499_TimerManual.pdf (if I can post links here), I substituted words in the "Set Mode" section instead. This is for the Utilitech 0149289 model and also applies to the Westinghouse and Stanley equals. Good luck.
3-Outlet Photocell
HEAVY DUTY OUTDOOR TIMER
Tri-Mode Digital Timer
3-Wire Grounded Outlet and Plug
6 in (15cm) AWG 14/3 SJT vinyl cord
Rated: 125V/15A/1875W Tungsten
60Hz
INITIAL USE:
Before initial use, please plug in your timer for at least 1 hour to charge the internal battery. After the LCD display appears, your unit will be ready for programming.
RESET:
Press the "+" and "-" buttons at the same time to reset your timer. This will clear all programmed settings.
SET CURRENT TIME:
Press and hold the "TIME" button to enter the current time. First, set the day of the week: press "+" or "-" button to set today's day.
Press the "TIME" button to enter the hour setting. Press the "+" or "-" buttons to set the current hour. Be sure that AM or PM appears correctly.
Press the "TIME" button to enter the minute setting, Press the "+" or "-" buttons to set the current minute.
Press the "TIME" button to finish setting the current time and return to normal display.
SET MODE:
Press & hold the "MODE" button to scroll between the different Mode settings:
Display Mode Explanation
Digital Timer On/Off at your exact
programmed times (Picture of clock inserted here)
Photocell Countdown Timer On at Dusk or On immediately,
Off after 1-12 hours (Picture of what looks like half sun on horizon)
Digital Timer + Photocell On at Dusk, Off at your exact
programmed times (Combined picture of clock and half sun on horizon)
SET PROGRAM:
After choosing your mode, set the timer program by holding the "PROG" button for 3 seconds, and then follow the appropriate section below.
SET PROGRAM: DIGITAL TIMER
The first setting is "PROG 1 ON" which should appear on the screen. Set the desired day of the week setting for your timer using the "+" or "-" button to scroll between choices. You can select each day individually, Monday to Friday, Saturday/Sunday, or the entire week. To have your timer turn On/Off at the same times every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press "MANU" to enter the "PROG 1 ON" hour setting. Press the "+" or "-" to choose the desired hour for your timer to turn ON. Be sure to cycle through until AM or PM appears correctly.
Press "MANU" to enter the "PROG 1 ON" minute setting. Press the "+" or "-" to choose the desired minute for your timer to go on.
Press the "PROG" button to enter the "PROG 1 OFF" setting. Repeat steps 2 & 3 to set your desired Off time.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and is ready for use.
SET PROGRAM: PHOTOCELL COUNTDOWN TIMER
The first setting is "PROG 1 ON". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until
Press "MANU" to enter the hour setting. Press the "+" or "-" to set:
Display Explanation
d Dusk to Dawn - On at sundown, Off at sunrise
d:01 to d:12 On at Dusk, Off 1 to 12 hours later
S:01 to S:12 On immediately, Off 1 to 12 hours later
SET PROGRAM: DIGITAL TIMER + PHOTOCELL
The first setting is "PROG 1 OFF". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press the "MANU" button to enter the "OFF" time hour setting. Press the "+" or "-" to set. Be sure to cycle through until AM or PM appears correctly.
Press the "MANU" button to enter the "OFF" time minute setting. Press the "+" or "-" to set.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and be ready for use.
MANUAL OVERRIDE:
Press the "MANU" button to choose the timer status:
Display Explanation
ON Continuously ON
OFF Continuously OFF
AUTO Timer will turn On/Off according to program settings
