SOURCE: Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
SOURCE: Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
SOURCE: Need replacement leather part of strap for 18K gold Tag Heuer.
ask them here..
Customer Service
Mon. - Thur: 9:30 AM to 6:00 PM
Fri: 9:30 AM to 3:00 PM
Phone: (877) 834-1434
Phone: (212) 924-9925
SOURCE: how to change the strap of leather to the gel strap technomarine
What is the reference of the watch?
On the Cruise collection, the process is very simple:
1.
(To
remove band) Squeeze the easy release spring bar to one side until it detaches
from the watch case completely, do the same for both bands.
2.
(To
attach new band) Take the straps that you want to put on and squeeze the easy
release spring bar with your (nail or screwdriver) and insert into little
groove, it should snap right into place
3.
Do
the same for other band
If you need more information, please contact us [email protected]
SOURCE: broken watch strap
Is it totally broken? Send me a picture of the damaged strap if you get a minute..I might have some ideas. JR8712 - is that a brown cuff one with the gothic seconds?? [email protected]
