Question about Irons
Wireing for dowsing snooker iron replaceing heater element and need help with with wireing need diagram ?
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Posted on Apr 06, 2009
Bosch iron TDA76 light comes, on no heat
Hello, welcome to Fixya!
The problem is either from the heating element or a disconnected/loosed wire.
Get a screw driver disassemble the iron and check for any visible wire disconnection or burn. If all wire connection in the iron are intact, then it means the heating element of the iron is defective and needs to be replaced.
Good luck.
Nov 04, 2011 | Irons
Light comes on but no heat
Good luck.
Is no workig i needcramic heat control
1. you need a multi tester.
2. check the power supply of your outlet, or check the fuse or circuit breaker.
if has power go to 3.
3.open the back of your electric iron, the end of the cord or plug. then try to check the continuity of two wires if any is open. if its open or no continuity replace the cord or plug, either cut the only open wires and reconnect it again.
4. Or check the heating element of your electric iron if no resistance replace the heating element or you buy a new one.
Feb 16, 2011 | Conair Irons
Iron does not get hot at all.
Your heater element was defective and need for replacement
Jan 12, 2011 | Hamilton Beach SteamExcel 14760 Iron
Iron is shutting off after about one minute even while I am still ironing - only about 6 months old
Hi, Seems the heater element was damage and need replacement soon.
Regards
Dec 17, 2010 | Black & Decker Irons
I have a Black and Decker D1650. It fell off the ironing board onto the carpet. Now I get error message OR and it will not heat up.
hello,
what his sign indicate is that there is disconnection of power connection over to the element i.e the heater (heat provider).
what you need to do to fix up this problem is to open (unscrew) it then trace the wire down to the element inside the system it self the element is silver in colour fix up the wire back, to the back of the element then with this the problem of the error message is solve. disconnect all source of power supply to the connected to it .
thank you.
Jun 13, 2010 | Black & Decker Steam Xpress AS250 Iron...
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
May 31, 2010 | Euro-Pro Shark GI490 Iron
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
The iron does not heat up
Hi.
Either wiring is broken or the heating element is broken.
Jan 15, 2010 | Steam Fast Irons
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Irons Logo
441 people viewed this question
Top Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
