I have the same problem, my washer will fill up with water and clean the clothes but just when it hits the spin cycle it stops. It won't spin nor empty out the water so my clothes are left in a pool of dirty water on the bottom of the washer! Please Help!
Tell me what is wrong and what I will need to do/buy to fix this problem...
Thank you!I have the same problem, my washer will fill up with water and clean the clothes but just when it hits the spin cycle it stops. It won't spin nor empty out the water so my clothes are left in a pool of dirty water on the bottom of the washer! Please Help!
Thank you!
AnonymousApr 18, 2009
could you tell me if it really is the pump or the timer could you tell me if it really is the pump or the timer
You can't post conmments that contain an email address.
Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly.
see this causes and fix it. God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. See There's no cold water.
see the next steps and use the common sense: God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
The typical cycle is; fills to selected water level agitates wash cycle drains wash water spins wash cycle fills to selected water level on rinse cycle agitates on rinse cycle drains rinse water spins final time end of cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Thank you!
