Sounds like a bad motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
You can check the capicator. This is mounted next to fan motor.
There should be 2 wires going to it
SOURCE: Diesel
well, somebody once told me that if you add a quart of oil to 5 gal of kero, it makes a good diesel substitute. So, in theory, I would add a little ethinal (corn gas) to the kero.
SOURCE: All-Pro Kerosene Heater
I have a 100,000 allpro Kerosene heater I get sprake but won't lite I need help Thanks
SOURCE: Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
SOURCE: master 110 torpedo heater will not start , kerosene type
open the vac pump off back of motor, clean and lube vanes and reassemble. your vac pump is stuck.
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
