Hello &
Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
