SOURCE: Bowflex 1090 selectech fault
The problem is that the composite disc or "circle" on the handle that holds the weight is cracked or damaged, thus allowing more play for the disc to move and by pass the teet on the weight itself.
I own these also, and I should have done some more research before purchasing them. I believe that a new handle (which is what bowflex will sell you) will exceed $100.
These things are not suited for the higher weights.
Both of my handles are screwed. I will be getting a set of Iron Masters in the future rather than repair these.
I hope this helps
Ray
If you have an issue with the SelectTech dumbbells of any kind, just contact the customer service phone number 1-800- BOWFLEX. All they require is a proof of purchase (receipt) to be sent in and they will send you any replacement parts free of charge. You do not need to send the old parts back first.
SOURCE: Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
