I don't know, I don't know. I don't know. Perhaps you could tell us what brand and what model camera you use? And perhaps you can tell since when it is acting strange? like after you dropped it, or after it went down in the swimming pool. Or perhaps just after leaving it alone for a few days or weeks. Or perhaps after you changed some settings?
You have a slow drain of power inside the car wiring. It could be a relay sticking closed, a short to ground somewhere, or a component using power when it should be switched off like a courtesy lamp.
The fuses have to be pulled to find the circuit with the drain.
E4 would suggest a leak or spillage of water into the base of the appliance.- Unplug the appliance. - Put some towels around the rear of it and tip it rearward about 45 degrees. - Drain the water out of the base at the rear corners.
Once drained, try the machine again. If
it fails very quickly then it would suggest a leak and you would need
to drain it again, take the panels off and watch it working to locate
the source of the leak. Cure the leak to stop the fault.
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
