Question about Amana Refrigerators
I have an Amana model no. ARS2663AW refrigerator with a built in ice-maker. The ice-maker keeps freezing up. By that I mean the tube that brings the water down to the ice-maker tray seems to freeze. This morning there is water leaking out of the fridge. This has happened about 6-10 times before.
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
Think of a water faucet.. You turn it on and water comes out and you turn it off and the water stops, right? Now when a faucet gets old sometimes it will drip and you have to jiggle it to make it stop.
In the back of the fridge you have the same basic thing. A valve that opens and closes to allow water to flow.. It is split into two sides, one for the water in the door and one for the icemaker.
One side could go bad while the other still works and that sounds like what is happening. Some have one and some have two depending on if you have a water filter but this one looks to be an oldie but goodie before the water filters were factory installed.
The part# you need is WPW10247599 and I fount it for under 40$. You need to unplug the unit and turn off the water to it. Change the valve and defrost the tube going to the icemaker.repair if needed.
I have an Amana model - whirlpool-invensys-service-replace-wpw10247599-ap6017730_04_l-5dtrzrhacenyq0nfrt1kdhhl-3-0.jpg
Posted on Jan 28, 2018
6ya staff
SOURCE:
22yooper
James Helmer
  • 828 Answers
SOURCE: Amana 25 Refrigerator Ice-Maker
Your problem may be at the electric valve where the water comes into the refrigerator. There is a screen and an orifice that may be restricted (plugged).
Posted on May 10, 2008
Anonymous
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Posted on Sep 18, 2008
Anonymous
  • 9 Answers
SOURCE: Why does the defrost water not go into the tray?
The drain hole in the drain trough is probably clogged up with some gunk.
Use a turkey baster and VERY VERY hot water to try and clear the drain line.
Posted on Jan 10, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: water leak in ice maker tube
Hi, Make sure the inlet tube has no restrictions. Sometimes ice will start to form inside the inlet tube and cause pressure so the hose leaks. If this does not help. you might need to change the change the inlet tube
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker
ON YOUR MODEL YOUR HAVE A MULTI-COIL WATER INLET VAVLE WHICH CAN BE ORDERED AT WWW.REPAIRCLINIC.COM OR FROM FOX APPLIANCE PARTS IN ATLANTA, GA
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Nov 04, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker fill tube
most will just slide back in... unless it was broken.. some are attached to the outside in the back and go all the way thu .. i couldnt bring up you model #
Aug 27, 2007 | Amana SXD524VW Side by Side Refrigerator
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
