Go to your heater and locate the circuit board inside. There is a 3 amp fuse that protects the board and it is a regular auto fuse and isn't made for any surges in the system. When you turned your generator on with the system on, chances are you surged the system and that fuse went. Breakers allow for surges where fuses don't
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
SOURCE: what size generator, watts, doe's it take to start AC unit 57915.531 ?
a 10000 due to the startup surge. also need start kits on any ac started by a generator.
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
SOURCE: Dometic Duo-Therm Model 57915.622 Fan will not start.
Sounds like your fan motor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Didn't realize this was an RV AC. Look for your fuse panel which should be by your breaker panel and check all the fuses
