Vitamix Super 5000 Work Top Blender Logo
Posted on May 05, 2011
Have a Vita-Mix 5000 and, need to replace broken speed dial. Advise where to buy replacement as Vita Mix Cust. Service ignores my previous emails and impossible to talk to a human been on the phone. Your prompt reply will be greatly appreciated. This is a great machine but, I am very disappointed with their service.
4 Related Answers
Anonymous
  • 15 Answers
  • Posted on Jun 11, 2009
SOURCE: need repair/service manuals for vita mix blenders
Here you go:
"http://www.payloadz.com/go/sip?id=889319"
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Jul 18, 2011
SOURCE: looking for instruction manuel Vita-Mix 5000
Welcome to Fixya. Vita-Mix did not provide an instruction manual for their blender since it is easy to use. You can check the link below for the function of the panel of the blender
Vita-Mix Instructions
Vita-Mix Schematics
Thanks
Anonymous
  • 75 Answers
  • Posted on Aug 21, 2011
SOURCE: Have had my Vita-mix 5000 for several years with
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 28, 2011
SOURCE: Vita-Mix VM0100A When to repair the start stop
Hello, jose
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
2answers
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
2answers
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
How do program my Vitamix vmo115e
Contact customer service, they will be great to assist you, they have for us many times.
Check here:
Contact Us Customer Service Vitamix
4helpful
2answers
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
3helpful
3answers
2helpful
My nblender just stop working, power in was good, no reaction.
Switch must be bad, remove the four screws on the bottom they are under the feet, then check switches, and replace broken one.
Top Vitamix Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
