SOURCE: Cold on bottom, Hot on Top - 596.75303
You are right on the money. I would definitely buy the fan kit because the problem will get worse. I had to replace the evaporator fan on my parents fridge and it was only two years old. You can also download the breakdown diagrams and schematics from http://www3.sears.com
SOURCE: panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
SOURCE: why does the water filter leak into the fridge
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: Kenmore refrigerator Model 253-68232800 will
Top of Form If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within. Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
