There could be three answers here;
Is the compressor warm to touch? Does the compressor motor run?
If the compressor is warm to touch and is not running then the compressor may be seized internaly. You will need a technician to repair it.
If the compressor runs then the refrigerant may have leaked out. A technician can help you with that.
If the compressor is not running and is at room temperature then you have a thermostat problem. A technician can help you with that
Hi i have a neff nef 4316 friger which fills up with water in the bottom compartment.over a period of time.
what can I do to stop this?, is it ok to continue using the friger ?
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the
freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the
refrigerator from main power outlet for 4 hours then reconnect it and check, if
the same problem is noticed again,. If yes then its defrost board problem. The
defrost board located in the back of fridge section. You can get required parts
from www.repairclinic.com or from online sears part site. ------------- Thank
you.
