The freezer coil has frozen solid blocking off air flow.
Manually defrost the refrigerator. If this works then you have a defrost problem. A technician can help you with that
Hi Over time debris, ice or food particles can get stuck or lodged into the vents. If the vents are blocked cold air is unable to properly flow through the unit. Cleaning the vents will cause the cool air to circulate throughout the unit once more. Check the vent to be sure there is no ice that needs to be melted. Defrosting the unit with a blow dryer for faster results may solve your problem. Another place to check is the refrigerator seals. Seals are what keep the appliances door closed. Cracks in the seal will result in a loss of cool air. This causes the unit to run continuously, which can ultimately lead the complete unit to shut down. It can also be the reason the temperature has increased. It is also a possibility that your refrigerator is not cold because of the evaporator fan. The evaporator is activated by the door switch, which comes on when the door opens. If the switch is not working properly it will not turn on the evaporator fan. Please check this link to troubleshoot your problem:- http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
