I don't know. Having said that, I would sugg3est you smack the bolt a good single solid blow then try RH again. BTW - Lefty Loosey ... Righty - Tighty.
I would expect it will be on very tight ... you might want to spray a product called Liquid Wrench or other penetrating oil on the bolt and let it sit for a while before you try again.
Try not to break it ... but if you do ... it is not the end of the world. You can drill it and use an "easy out" to remove the broken stud from the hole. Get help on easy out and drill size before you start if it gets to this point.
