SOURCE: Everything works fine but my dark clothes always come out with white marks on them.
there is not a filter that you can clean easly you can take your agitator off and clean what you can get to.the lint should drain away at every drain cycle.
when you take off the agitator off you may see 2 holes about the size of a quarter they have what looks like little combs in it this may trap lint
SOURCE: Hi. I have a Whirlpool Duet Washer and Dryer. The
.Their are a number of small holes in the top of the housing that let the fresh water down into the tray causing the soap or the softener to run into the washer these easily become clogged thru no fault of your own and can not be properly cleaned Another problem could be is the cam assy. that's mounted on top of the dispenser housing is not working correctly, This is the same model I have here at home and had the same issue.My solution was just to replace the entire dispencer assy parts about $65.00
Testimonial: "Thank you so much - helped immensley!"
SOURCE: When washing dark clothes in my Cabrio washer they
Hello harnweys. Definitely switch to another brand of HE detergent, and always choose a liquid as opposed to a powder. Finally, be careful not to overload your machine, set the water level to a higher setting too! Joe
Thanks for choosing Fixya!
SOURCE: When washing dark clothes in the Cabrio washer I
wow,. I have the same machine,. never encountered this one... here are a couple things to look at
Are you on city water or well water? if a well, you may need to test your water or make sure your water softener is up to snuff, otherwise if on city water, what kind of pipes are there for water pipes in your house? If they are older galvanized pipes there may be calcium build up which may be getting into the screen.
How about the water temperature? Have you tried different temperature water to see if it continues through the wash cycle?
also check to see if you have a filter screen in the water input line
If n o avail, try the owners manual that came with the washer and or try a call back tot he company and get a different cust srvce agent, the one you may have contacted may have been having a really bad day and didn't give you proper attention?
Best regards
Ck
Camp clotheslines are usually constructed of sturdy aluminum and are capable of holding a reasonable amount of laundry. The string is usually some kind of a rope, a twine or a cored that is stretched between two points.
