make sure you have the correct plugs for it. spark plugs that are too short will cause a condition like that. make sure your air filter and fuel filter isnt clogged.
jm
You might have sheared the flywheel key if you hit something hard. its usually under the flywheel bolt. they are made to shear off if you hit something really hard. it will run but not restart...
jm
I thought about that or a loose or broken magnet under the flywheel. But the thing starts rite up and sounds good not missing at all. But it seems like when you put a load on the engine the engine almost dies. What it sounds like is you pull the throttle back on it. It doesnt miss it just boggs way down. Like it looses at least 50% power or more. Its like it needs the timing to be advanced. But isnt the timing fixed on those?
your best bet now would be to call a lawnmower shop and see if they know a trick or two. It sounds internal to me. usually Kohlers are trouble free but you might have gotten a dud.
jm
I have heard mixed reviews for these engines. I have only owned a single cylinder kohler. my friend who has a small engine shop seems to always have one of these two cylinder jobs on his bench torn down....
hi I checked ,plugs and air filter both were good. It seems to have all the fuel it needs. I sprayed either in the carb when it bogged down and the engine rpm's didnt come up it actualy got worse. It seems to me like something in the ignition or timing something along those lines. I dont know how that ignition system works. last year I replaced the coils they both went bad within a month of each other. Very frustrating any other ideas would be great. Thanks
