It has been freezing up... i have defrosted with a hair dryer... i turn off the freezer and defrost... this time... when i turned on knob to cooling the freezer would not come back on...nothing.
I do feel that I have a defrost timer issue... but, now I have nothing it usually kicks the motor back on... help please... limited funds... was just trying to keep it going.
thank you for your time with this.
jeannine
Just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
There is the drain in the freezer under the evaporator. You have to remove the rear panel in the freezer and the freezer floor to access it. Defrost it using a hair dryer and put hot water through the drain to make sure it's clean. Make sure the bottom end of the drain hose (behind the rear cover) is clean as well. Vacuum everything in the compressor compartment and keep it clean.
Please check the useful links bellow related to your query...
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
http://www.ehow.com/about_6736707_water-freeze-floor-bottom-freezer_.html
http://www.ehow.com/how_2208484_that-leaks-water-down-refrigerator.html
Let us know if you want something else please accept the solution.
thank you for taking the time to send this... something to consider..jeannine
