SOURCE: LG 37LC7D remote doesn't work
Turns out there is a problem with certain LG models made in Mexico during May. Not only did the remote stop working, but the TV started shutting itself on and off randomly. Took it back and exchanged it for a Panasonic. Not putting up with that, LG.
SOURCE: LG Flat panel tv
Adjust Color in menu option.
Keep a sufficient distance between the product and the VCR.
Try another channel. The problem may be with the broadcast.
Are the video cables installed properly?
Activate any function to restore the brightness of the picture.
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
