Kenmore 43142 Front Load Washer Logo
Posted on Apr 27, 2011
Machine wash ok but would not spin to take the water out of the clothe
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Apr 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1603
Points
10
Usually, this problem is due to a clog in front of the drain pump not allowing water to drain properly.
Remove the front lower panel by removing the 3 screws along the bottom (front).
The large plastic (3") cover of the "coin-catcher" in front of the pump then needs to be removed. It is easily seen facing you when you remove the front lower panel. **WARNING** All the water from the tub will come flooding out. I like to use a shop-vac with the nozzel placed at the bottom of the cap as I unscrew it SLOWLY!!!
The coin-cathcher (lint filter) is part of the cover and you will find it loaded with years of ****.
Jeff
2answers
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Spin cycle not working properly
What is the model number of the unit?
2answers
Water can't out from macshine went i want to wash
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
2helpful
2answers
I purchased a whirlpool washer (model # WTW5600SQ) in 12/07 and the spin cycle does not effectively remove enough water from the clothes. The clothes,after the spin cycle completes, are still very heavy...
Hi Tim, Check the filter to see if it blocked .. also, take note to see if the machine is gathering a full spin speed, if not, you may need new brushes in your motor
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Washing not spinning water out of clothes
Must be something in the pump obstructing the water flow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4helpful
2answers
Lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had a similar problem i unplugged the machine and left it stand for 8 hours .. it works ok..
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Alexander
vince
