I have a 4 year old Whirlpool Dryer Duet model number GEW9200LW1 and was doing several loads of laundry....and when I went to do the next load, the light went out in the dryer and the dryer is locked in a mode whereby I cannot start the dryer. It just gives a few beeps and keeps blinking. I tried to restart by changing the bulb, clearing everything and unplugging the dryer, but it is caught in this cycle. Also, the light stays on when the door is closed. Any suggestions?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock
problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
Catriver, The door closes on a plunger that is attached to the frame of the dryer. When the door is closed the plunger pushes in. The plunger is under a rubber cover. The plunger seems to be of the same type that is attached to the car chasis and when the door closes it turns off the dome light.
Our 4 year old dryer(gew9200lw1) had a burned out heating coil that I replaced do to the dryer filling up with lint!. I was told that this is a common occurance with these dryers and to clean them at least once or twice per year. Removing the doors and panels and clean inside & out.
A new problem started yesterday. The dryer quit and will not start. I did all the diagnostic test according to the maintenance tech sheets provided and everything seemed to check out. Until- I discovered that a QUARTER had fallen through the lint screen, when it was opened, and lodged on the thermal fuse located on the blower exhaust housing. I have power everywhere but when I try to start the dryer it just clicks. I suspect that the circuit board(control board) has a burnt diode, fuse or something that is preventing it from starting??
I have the same problem. My duet dryer bulb went out and at the same time the dryer won't start either. If I close the door it just beeps twice and then flashes.
