The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
